Need Help DESPERATELY!!!. What causes lifting when Sherwin Williams precat is applied over solvent based stain and filler sealed with shellac and one coat of conventional acrylic lacquer. The problem appears after intra-coat sanding. Blush retarder was added to the precat. Any ideas of what is going wrong? Any ideas will be greatly appreciated.
Sounds like your addicted to chemicals to me. Too many irons in the fire so to speak.
Can you expound? Really need help.
Get out the stripper, and try to keep finishing as simple as possible.
You cannot apply a catalyzed finish over a non-catalyzed finish... it causes wrinkling. Even among catalyzed finishes, different brands used in layers can cause wrinkling.
I also would not use shellac in this schedule. If you want a sealer, use the vinyl sealer that goes with the brand of lacquer you're using. Vinyl sealer is a drop in replacement for shellac in this application (excellent adhesion, barrier coat, improved moisture resistance). If you're just looking for a sealer that sands easily, to establish a smooth base for the topcoats, then check with your supplier to see if they have a sanding sealer instead of the vinyl sealer.
If by lifting you mean there's an adhesion problem, then it's clear the 3 different finishes you layered don't get along well. Stick with the products and application guidelines listed on the data sheet for the pre-cat lacquer. Sherwin Williams has all their product data sheets on-line if you didn't get one when you bought the lacquer (http://www.sherwin.com/oem/us/eng/products/categories/clear_topcoats/). They also have the material safety data sheets at the same link.
http://www.finishwiz.com
Thank you! This is what I suspected. Again, thank you.
I can hear the finish screaming: "GOTCHA"!
Sorry, had to say it.
Chris @ flairwoodworks
