Project planning and introducing myself
Hi guys,
I recently built a SMALL workshop only 9 x 13 feet using 2 x 2 frame and 9mm OSB sheeting. Our garden is small 22 x 57 feet (even then the grass is negleted). The two walls on the garden side are clad in red felt shingle tiles– it looks okay.
Alot of my tools come from two cheap German supermarkets we have here in the UK, yes I read about the super pro-kit that is on the market, but I can’t justify it on price or use, I am only a hobby man.
I get satifaction through improvisation (or am I rationalising becuase I can’t afford the good stuff). Sometimes I try to mimick the tools I see in the catalogues, I learnt to weld which is good for fabricating brackets etc.
I have been reading some of the letters, and its good to see accomplished people willing to help others.
One way I start a project is to use the DRAW facility in MS WORD. It can use metric or imperial and is particularly usefull for a cutting plan on an 8′ x 4′ (2440 x 1220mm) sheet. One can even allow for the 3mm kerfs. This may be old stuff to some out there, but to others it might be an easy way to utilise a computer with a readily available drawing program without having to learn CAD, (something I would like to do, not yet found the time).
Anyway thanks to everyone for their help with all the topics and HAPPY CHRISTMAS
Hi Steve
Nothing wrong with a bit of improvisation which all ads to the important aspect of the woodworking game "Job satisfaction"
Thanks for the MS word tip on utilising the 8x4 sheet on the PC.
What sort job's are you doing at the moment in the newly built workshop. Space is always a problem in the UK which comes with a high price. Let us know what you are up to. As it seems that we share common ground. The money factor.
Johan
Thanks for your reply Johan.
I'm the preverbial recycle man. Take a piece of wood--painted, second hand, part of a furniture piece or whatever, saw it/plane it/shape it and it's no longer the same piece anymore. Once it has been made part of another masterpiece who cares about its origin, and it's another piece saved from the skip.
So in that connection I am converting a drop leaf table (only one leaf left) into a computer desk with shelving above (as resquested by the boss she who must be obeyed). The challenge is to do it without buying any wood. The sides and top are the slats from a bed edge joined, the head board is used to make two shelves. I am also using some plywood that was a model railway base, a knot was utilised as a "pond" this I repaired, also some block board both front edged with real wood. The whole thing to be stained with antique pine.
By the way my "saw bench" that gets most use is a Wolfcraft multipurpose one that takes jigsaw, router and circ saw. The baby B & D gets most use.
So there you have it, tell us what you are to up Johan.
Hi Steve
Nice to hear from you. I dont know how to use the drawing facility on MS Word. I have tried playing around to see if I can make sense of it. All I can do is dragging a sqaure with the mouse and a right click. Any Idea's or pointers how te get started with drawing this 8x4 sheet and how do you do it to scale? Would it be possible to add in an attachment as an example on your next reply.?
Judging your working enviroment. Have a look at the following website http://www.hegner.co.uk Just an Idea. You never know.
Look at the Unicut 2. It is an small work bench with a mounted sliding arm for which you can use the circular saw,router,small angle grinder in for Rip & crosscut with mitre,overhead routing and for cutting metal. If you ask them they will send you a free tape which demonstates the endless things that you can do with it. Ideal for the workshop you have.
At the moment I am working on a house built in 1598 as an ongoing project. I left the office job for good about a year ago.
So a this precise moment I will be laying a solid wood oak floar. Did a lot of carpentry work on the house already in the past like making new windows, re hanging doors skirting, architrave and so on.
My next challenge wood be to make doors. Never done it before and never seen how it is done. So I still have to do a bit of research on that. Need to make 25 bespoke doors for the particular house which consists of 13 bedrooms.
We will speak soon Steve. I am off to do a bit of shop fitting after shop hours.
Hi Johan, nice to hear from a busy man, you make me feel a bit humble with all that before you. Good luck hope it all goes well. Thanks for the web site tip, I'll keep that in mind, it's nice kit, I'd better rewrite my letter to Santa, again!!
As for MS WORD DRAW here we go then: I'm assuming your Word edition is fairly recent. You found the "square" starting point so the drawing tool bar was selected. From this scribe a square any size, keep it highlighted, double keft click or right click, this will get you to Format Autoshape, click on Size to prescribe the precise dimensions. I use metric so for a 8 x 4 foot use (2440 * 1220mm) this makes sense when using a 1:10 scale, I prefer metric for precision anyway simpler than all those eighths. Remember if you rotate the drawing; the length becomes the height etc., but the computer does not know this, if you know what I mean. There is also a simple 3D effect gives the drawing a bit of realisam, if needed. If you want to change the measurement system metric/imperial; click on TOOLS/options/general .
Hope this gives you a start, once mastered you can do a lot of work long before you go to the workshop and reduce wastage--got to be a good thing.
All the best Steve.
Welcome to Knots Steve,
Good tip! I've been screwing around with an excel spreadsheet but that took much longer. I wish I'd had your tip about a week ago, but I'll use it next time.
BTW, how are you allowing for the kerf? Are you making separate boxes only .0125" (for 1/8") wide and attaching them to the other boxes?
Dan
Hi Dan, Yes I have made boxes to allow for kerfs. I found a way to acheive the right proximity without overlapping. Click on Draw on the Drawing toolbar, then on Grid; this will allow the adjustment of the incremental movement of any highlighted figure. Also from this menu you can decide the order of overlapped figures, plus if you are doing a sketch of a project you can group a selection highlighted figures to move in "unison as one" eg., where the project is in two sections. For this click on the arrow pointing north-west, draw the dotted line around the desired figures and select Group.
Good luck, yours Steve
