Its been a long time since I desined a bar, and now I have a costomer who wants one, my memory tells me 42″ is the standard bar top height, this seem low , does any know what the standard is.
thanks mark
thanks mark
Are you referring to the bar from behind which drinks are served, or the kind you find against the wall (more like a railing) for you maybe put a drink on, but definitely to lean on?
Either way, I'll try to remember to measure for you Friday night ;)
d-
"proper height for your beer," woodshaver?
I'd say lip height------ and sinking. Slainte.
Website The poster formerly known as Sgian Dubh.
You're ahead of me again, Richard.
I saw the title and immediately thought:
"about belly button height, but on the inside."
Eddie
Sounds to me like it's a good excuse to go to a bar and have a couple beers. Bring your tape measure and you can write down measurements on the back of a cocktail napkin with the waitresses pen...
Maybe I'll go do it for you and report back :)
Don't forget to write it off your taxes as a research project.
Philip
P.S. some research projects last years...just an idea.
The 2986 that I have measured are approximately 45". Same as a bank counter, customer service desk, etc. Not sure about the others. ha..ha..
sarge..jt
Don't forget to make the utility side 36" high.But honey, I can make money if I had just one more tool. Really.
42 inches is a standard height when you add 1 1/2 inches of countertop to that
comfortable for sitting on a barstool
On a more serious note:
According to "Humanscale," from th MIT Press.......for the average adult of 66" tall, the height should be 42". For the average male of 68.8" the height goes up to 44" and for the average female of 63.6" the bar height should be 40 3/4 " or so.
But....perhaps you ought to work backwards into the answer by starting with the height of the stools. If they are yet to be purchased, I suspect that they will only be available in certain heights that you will want to know.
Just a basic ergonomic rule of thumb or guide line : countertop should be approx 12 inches taller than the seat hieght . good luck
thanks for refreshing my memory . everyone. its time to empty that beer, then start designing that bar in the morning. again thanks
mark
I love Jim Beam (too much), but I just checked an old (Sixth Addition, 1974) of "Architectual Graphic Standards" and standard bar heights are 3'6" to 3'9", 5" to 6" top overhang and 8"+ rail projection (no height?).
Forward!!!!DRINK!!!!!
Enjoy, Roy
Edited 5/4/2003 12:58:51 AM ET by ROY_INMD
You all have it wrong. Bar counter height should be the same height as the bottom of the most buxom barmaid's boobs. This will neither obscure the bartender's or patron's view and will provide much needed support while said barmaid is waiting her order to be filled. This support will also tend to improve her posture and reduce fatigue. Therefore the combined effect of having your barmaid noticed sooner will be that your beer will reach you sooner and be brought by a happier, friendlier barmaid.
Cheers!John O'Connell - JKO Handcrafted Woodworking
