I am purchasing some red oak veneer for some cabinets. Previously I’ve used paper backed veneer with adhesive and am wondering about the reliability of PSA adhesive backed veneer. I am considering it because it wouldn’t have the of the fumes of veneer adhesive and it seems easier to apply. Will it tend to lift over time? Any other problems with it.
I’m not a pro but my usual criteria for materials is if a pro wouldn’t use it in their home then I don’t want it either.
Every experience that I've had with any adhesive veneer, the veneer has eventually lifted or bubbled at some point. Especially if they're hung in high humidity or damp areas. I primarily used the veneers on Yachts & sailboats, so it's always a damp area. I have always been successful applying liquid nails on the backside of veneer & formica. Then I touched it to the dry surface areas and let it sit about 5 minutes prior to permanently applying it to the dry surface area. This helps tremendously with the cure time. Then I placed cardboard on the veneer to protect the finish, prior to using a weighted roller to squeegee the excess adhesive from between the two surfaces. Once you make sure that any bubbles have been rolled out, tape down the cardboard for protection and place something weighted on top overnight so it cures completely with no bubbles.
