I want to purchase an air comressor for my medium size (24×24) shop. I will use it mainly inside for stapling and small nails but occassionly would use it outside for small painting and sandblasting jobs. I am thinking in a price range of about $250 – $300. Any reccomendations, suggestions?
Check out the Porter Cable CPL6025 compressor. I've been using mine every day for 5 years. 6 peak HP, 25 gallon tank. Actual running HP is probably more like 2. I just ordered a new pressure cutoff switch for it. I got mine at Lowe's.
PlaneWood
I'll second the P-C
John
Here are a few thoughts for you:
1) You need only a small, portable compressor to run nail guns, but even "occasional" painting/sandblasting would require a much larger compressor.
2) There have been many discussions of compressors here and at Breaktime. If you do a search you will find a plethora of info; from my reading of all these comments, PC would not be your best choice -- Rolair and Thomas would be better brands to consider.
3) some compressors are substantially noisier than others; again, from my reading, PC is among the loudest.
4) Before you simply make a compressor selection from the shelves of a big box store, it would not be a bad idea to find an industrial tool outlet in your area (where you'll find Rolair and Thomas) and see what they have to say.
Good luck.
John Wooden 1910-
Hopefully your idea of a small sandblasting job isn't much bigger than a toaster! Sandblasting takes a lot of air. I have decided to sand blast my brick fireplace mantle (4' x 13') and remove it's 35 year old accumulation of paint. I bought a small sandblaster from Harbor Freight and went after it with my 4hp 30 gal compressor. It took almost 2 full days! I swore if there was a next time I'd rent a seroius sandblaster.
One word of advice - if you get a compressor larger than a pancake or a hot dog for basically just nail guns, DO NOT, I REPEAT, DO NOT GET AN OILLESS! They are just too damn noisey.
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
Edited 9/6/2005 9:12 am ET by Elcoholic
To all who have responded to my inquiry, thanks. I think I will take your advice and get a portable compressor. If I need one for painting or other big job sounds like I would be better off renting a bigger one. Regarding the Porter-Cable, I have heard or read other negative comments about them. The local HD has a Rigid double tank portable on sale for $259. Does anyone have any experience with them?Norm (never been on TV)
KMS Tools has some useful information on air compressors in order for you to make an informed decision. Go to http://www.kmstools.com and click air compressors under quick index. Then click on compressor buying guide.
Bill
