Hi Peter,
Your background seems to be most relevant to the problem I’m having. I’m working with purpleheart wood, and my application involves displaying the end grain. Every time I slice off a section the purple color disapppears, and I’m left with a deep brown color. Over time, the color returns, so I assume there is some oxidation process going on. I don’t think the end grain has much to do with it, because if I surface plane a purpleheart board, the same thing happens. Obviously, I’m choosing purpleheart for its distintive color, so brown purpleheart does nothing for me. Is there some way I can accelerate the return-to-purple process?
Any help you can give would be greatly appreciated.
Thanks so much for considering my question.
Regards, Dave
Dave,
I don't work with purple heart enough to give you a definitive answer. You may be able to use a water dye and get a close match. The dyes I use are from W. D. Lockwood. They have a very good selection of blues and violets that may fit the bill.
Good luck,
Peter
