I want to make 1/2 x 1/2 square pegs in walnut for cross-pegging tenons in a cherry mission style bed I’m making. The exposed ends of the pegs should be beveled to yield a pyramidal shape, but with flattened top, not sharp to a point. Any thoughts on how to produce the end detail?
Gene,
I use several very sharp chisels. I like a 1/2" and a 1/4". It takes some practice, but once you develop the feel, it's a very nice way to finish pegs proud of the surrounding wood. End grain can be shaved very carefully if your chisel has a very sharp edge. You have to learn to both push the edge through the tissue and "hold back" at the same time. The slicing action has a very satisfying "brrrp" sound and feel.
You can also tap lightly with a mallet.
Finishing pegs like this leaves many little burnished facets which are attractive in the final finish.
Rich
I normally use 5/16" square pegs. I've have had good luck using a box cutting knife with a new single edge razor blade. After carving them I like to lightly burnish them over with 600 grit SP.
