Q: retreiving “lost” data on a mini disk
Hi Gang,
I have a non-woodworking question for the group. Let me begin by saying that I know I’m an idiot. View Image
Masha and I are working on a new book and we had just finished a two-hour interview with someone that we were recording onto a dedicated mini-disk player (Sony MZ-RH910).
Instead of pressing ENTER to “write the file” to the disk I pressed cancel. The Hi-MD disk was brand new, so I assume that it was initially all zeros. I also assume that the data is on the disk (there is no memory in this device) and an end-of-file mark simply wasn’t written. I’m looking for a hack to load the data to my PC and write the “end of file mark” so I can read it.
Just spoke to Sony tech support. They referred me to a third party company (driversavers.com) who will attempt to do the work for $1500!!!
Is there anyway to read the disk and write that mark? Or if my assumptions are wrong, what else can I do to recover that data? Or can you point us to forums where someone would know the answer?
Thanks, Kim
_________________
Kim Carleton Graves – author of “Dining Tables”
Brooklyn, NY
Kim, I have a friend who's daughter spilled coffee on her laptop, which had 10's of thousands of $$'s worth of work in it. They had that whole hard drive recovered for about the same cost you quoted. The price they gave you seems ridiculous!!
You being in NY, seems like there are probably quite a few local recovery businesses around. I'd try a couple of things.....(1) pick up a Computer User or similar free computer publication and look for ads; (2) look in the Yellow Pages under computer repair; (3) check with any local colleges that have computer science programs. Maybe there's a grad student who could do it for you. Scary, but might work.
Hi FG, It looks like Hi-MD data is non-recoverable because it's "encrypted" by proprietary software. Reason enough not to use it for critical apps - IE voice recording. But given that's the feature that distinguishes Minidisc from simple playback devices, there doesn't seem any reason to buy a it over the standard MP3 player. Arg! Kim
Hi Kim,
I too think $1,500 is rather exorbitant given that, as you indicated, the problem appears to be the end-of-file record or lack thereof. Looking at the specs for the Sony MZ-RH910, it looks like the only Output from the device is speakers/headphones? Input is USB thus allowing downloading FROM your PC?
Most digital recording devices write what are sometimes called overhead records so the read portion of the device "knows what it's dealing with". If those records are either missing or contain invalid data, then the device simplay can't read the recorded data because it doesn't know where to find it. Not all recording devices record data in a contiguous "stream" as do computers.
Forestgirl: Since I can remember (over 37 years working on computers), hard disk drives are for all intents and purposes, "air tight". I would be quite surprised if any coffee actually got into the drive. More likely the coffee may have adversely affected the connections to the drive, or some other part(s) of the laptop, thus rendering the disk drive inaccessible (spell).
I've recovered computer hard disk drives that someone accidentally formatted! In days of old, what used to be called the CE (Customer Engineer) Track was always written when data was saved to the hard drives, in addition to the "user accessible) data.
Wish I could be of more assistance,
Kidderville, NH
Use whatever tool needed to Git 'r Done!
Wow, I'd never thought minidisks were still used...I'm holding on to my beat up sony MZ-R30. Metal construction that would take a hammer blow, it's just a little walkman w/the record function. Mine has an optical out, does yours? maybe that may offer another avenue to explore. I have about 50-60 albums I recorded to minidisk about 10 years ago now and still listen to them, oddly enough, in the shop.
