I’m about to tear my hair out looking for quality hex shank drill bits. Each brand of bit I’ve looked is rated both as the best thing ever made or a complete piece of crap. I’m sure this has been asked and answered before but I didn’t want to scroll through 700 pages of posts.
Thanks.
What kind of bits? You say hex shank, but do you need just regular HHS twist bits, spade bits, augers, brad point?
I'm not usually one to go for hex shank drill bits. There's too much play in the connection between bit and tool. I much prefer the tight and strong hold of a regular chuck.
That said, I've had some Irwin spade bits that have worked quite hard and quite well for a number of years. I picked up some Freud Diablo auger bits recently that seem decent... Both of them are hex shank.
Milwaukee stuff has always held up well for me, too... I like Dewalt drill bits as well. They both make hex shank bits.
I've also got a pile of hex shank bits that came with various bit sets over the years that I just never use.
I was looking for twist bits but you make a good point about straight shank. I get lazy when I have to chuck different bits several times during a project. Thanks for your response.
If you like hex shank and want better bits you could consider buying something like this.
https://www.snappytools.com/product/40020-7-piece-drill-bit-adapter-set
This way you can exchange the bits for the ones you want.
Just a suggestion
I'll look into those. Thanks.
I use hex bits a lot for general use, not fine woodworking. I usually use an impact driver with a hex chuck, not a drill.
But hex bits are just not made to the same tolerance as a high quality twist drill. I use a couple of brands, but usually whatever is on sale. I probably use Ryobi more than any other. I treat them as disposable, more or less.
Disposable is the key word. I break so many or they quickly dull--usually the cheap ones. Thanks.
Try Wood Owl OverDrive, Or Star-M F-type, same things, highest quality
I usually use Haisser
I'm all in for Irwin. I had so much success with their forstner bits I tried their hex shanks. You can't go wrong with a good product.
Mikaol
