I have some beautiful Qsawn woak that I am using to build a bookcasebanco unit. There is a lot of surface area.
I would like to end up with a durable dull sheen finish…brown to reddish-brown.
Is there a way to make the grain “pop”?
The ray-fleck patterns in quartersawn white oak will "pop" with any finish you apply, including a clear finish with or without stain. But if you want to maximize the effect, use a dark pigment stain and apply a shellac or varnish or lacquer finish over that.
*Thanks for the advice.... it works!I think I might try a medium stained grain filler and then apply a dark water based analine dye with a top coat of lacquer. Do you think there are any chemical conflicts with this process?
*Yes--I would not apply a water-based stain over a solvent-based filler. Stain first, let that dry thoroughly, then apply the filler.
*Building a Baker's Rack for my daughter out of white oak. Will stain medium brown, then finish with an oil finish like Danish or Formby's tung oil (NO alternative - her orders!). Any suggestions on what brand of stain to use under that oil finish?
