I have a small compressor that I would like to pull a low vacuum with. If I stick a hose in where the air filter is to do this will I mess it up? I can open the tank drain so it won’t be doing double duty.
Just wondering if I would wreck it. It’s a nice little compressor and I would miss it sorely.
I'm no compressor expert, but I noticed that the owner's manual of my Porter Cable pancake compressor has a specification for what maximum percentage of time the compressor should be running. I'd suggest checking that out first.
Likely what would happen is the oil in the crankcase would get sucked up into the cylinder and, if the vacuum were able to get to a sufficiently low level, back-stream into whatever you were pumping. If there were sufficient oil as to fill the cylinder without the compressor seizing first, the compressor would probably break a valve (oil being non compressable).
Having said that, I have read of people using refrigerator compressors as a vacuum pump. Having spent a great deal of my time in high-vacuum technology, I just had to shake my head, LOL. But, if it works, well then it works.
Compressors are usually used to pull vacuums via the venturi effect; i.e., the compressed air output is connected to a venture chamber, which will then draw air through a vacuum port.
Do a google serach on "venturi vacuum pump".
Start here http://www.joewoodworker.com/veneering/welcome.htm
LOL
Due to the head space in the compressor cylinder head, you won't draw much vacuum. Put your finger in the air suction hole, and you'll see what I mean.
Not sure of the application, but you will probably get better performance with a vacuum cleaner.
If you are building a veneer bag system, you use a venturi vacuum pump, which is a little inexpensive gizmo, connected to your compressed air delivery line. This will give you some real good Hg.
Here is a link for you.
http://www.vaccon.com/venturi.html
Thanks Jellyrug, I'll look into it. I was just wondering , ya know.
