I am building a round, dining room table that was designed by C Beecksvoort and published in a FWW publication. The table is 48″ in diameter and is divided in two so that it can expand. In the article Mr. Beecksvoort attaches the top to the rail by drilling holes the entire way through the 3/4″ rails and then attaching the top by screws with holes elongated to allow for movement. This seems like it would weaken the rails. Has anyone else used this method? Does anyone have any recommendations? I have read that wood “buttons/tabs” that are attached to the table top and then fit into grooves in the rails work well but have not had any experience with them. Any suggestions would be greatly appreciated. Thanks, Bill
Tables that expand to take leaves, need to have the "free" ends of the table apron rigidly fixed. The expansion and contraction takes place at the ends of the table away from the seam. In the tables I have built, the ends of the apron are fixed with a triangular gusset then the rest of the attachments are buttons into slots in the apron. I put a dowel in the center of the moveable apron that rides in a slot in the tabletop. This keeps the table centered on the apron but allow for movement.
Carefully think about wood movement when you engineer a table with leaves.
I've used the button tabs, and these worked reasonably well. They can be easily handcut or bandsaw cut. Used a small circular saw to slit the rail to hold the button tab. Please note that I said "reasonably" well. I guess I never liked the visual lack of precision of the technique, plus I had some break in transporting the table. So this method of drilling elongated holes through the rail is getting my interest, and I have I project that I just might use it on this June.
I've used homemade buttons on many tables. I use a 1/4 or 5/16 tongue on the buttons and rout the appropiate groove in the aprons. So far, I've never had a problem. Art
If Mr. Becksvoort is comfortable with this approach, I would be also. From his articles I believe he is very experienced and professional. Also, it seems this approach has been used successfully for hundreds of years.
