I’ve been working on a rocking horse (mostly made of Ash with some exotic reddish-wood for accents) and am approaching the end of the project. I have sanded the work and am proceeding to the final grit (220). I’ve been using Norton 3X sandpaper and am very pleased with the results thus far. However I have head that this “no load” paper may cause problems in that the “stearates” that are found in it may prevent absorption of the stain or adhesion of the polyurethane.
Is this true? and if so what can be done about it? Has anyone ever used this paper and had/not had problems later? All comments would be appreciated.
Thank you
Stearated paper has been used for between coats sanding in production finishing for the 35 years that I have been doing it, with nary a complaint. In fact lacquer sealers and, I imagine, oil based sanding sealers contain stearates to make sanding easier.
I have heard some assertions that stearated paper causes some problems with waterborne finishes, but I don't give that much credence myself. I strongly suspect that the cause is due to other forms of surface contamination, such as a failure to thoroughly remove sanding dust, or even the "wrong" type of tack cloth. Even WB sealers have agents in them to make sanding easier. I never bothered to look to see if they were stearates or something else. In case you didn't know it, stearates are the basic active ingredient in soaps.
Michael R
Being a sucker for warnings such as you mention, I've mostly stayed away from stearated paper, but it seems like a quick wipe-down with mineral spirits or Naptha would take care of any potential problem. From the post above, really doesn't seem like there's much to worry about.
I got to thinking, and checked my copy of Flexner's Understanding Wood Finishing. He says zinc stearate is used in almost all sanding sealers, so I think that answers the question pretty well.
Michael R
"You have to look for possibilities where there are none" Krenov
Edited 4/19/2005 11:09 am ET by Woodwiz
