I am building a pair of drawer front nightstands out of maple. They have 4″ x 3/4″ aprons attached to 11/2″ x 11/2″ legs. Through a mistake with my test piece (I forgot that I had put all of the “real” aprons though the planer for a final pass, leaving the test piece slightly thicker) I cut all of the tenons thinner than the 3/8″ I had planned. So I took them all down to 1/4″. My question is this…though less than the “ideal” are 1/4″ thick tenons thick enough given this piece? I would be more concerned if it were a kitchen table or coffee table where it would take more abuse. Obviously this is not a mistake that will be seen, but is it one that will haunt me down the road? The tenons seem pretty stout to me, and I will probably pin them. Am I concerned over nothing, or would you make 6 new aprons?
They'll be fine....just cut the mortises to fit....
Edited 9/28/2006 12:50 pm ET by CStanford
I agree with Charles.
Not to worry...........
John Wooden 1910-
Hello ThreePuttJoe:
I just finished a bedside table and all of my joints in it were pegged mortise and tenon. My tenons were 3/8". Your 1/4" will be plenty, as the strength of the joint comes from the amount of surface that gets glued and the pin/pegs. Your table will be just fine and as strong as can be.
Don
Absolutely nothing to worry about.
DR
When you stop to think that some pieces were put together with a couple of 3/8" dowels, A full 1/4" tennon is still far superior in mass and strength. No worries !
Bruce S.
Thanks all. I figured I was alright...but I wanted to be a little more positive before spending a lot more time on the project, and expecting it to last a good long time.
