Gary: First, I want to thank you for your frank, direct teaching on the site and in videos. Your experience and encouraging tone are so welcome!
Want to scribe and mortise a brass strike plate on door jamb…3/4″ wide, about 3.5″ long, 1/16 thick…pretty basic. I have a small 271 router plane (1/4″ cutter) which I have confidence in. I am planning on just using plate as template, knifing and paring edges. Plate has round ends…so seems logical to tap lightly with a 3/4″ dia.gouge, pare for nice clean lines… I got a scolding from Woodcraft sales fellow…says I should create a jig for laminate router with stops, etc. Seems like too much work for one task. How would you accomplish?
Dear Spazapple,
Thank you for your kind words.
Your first instinct is perfect. Let the router jockies run in fear from hand tools. Your method is simple and will work just fine. If you need you could run a router around the inside of the area of your scribed lines to get the depth perfect. But finish all the lines up with some clean chopping cuts with chisel and gouge. You’ll be done in the time it takes to find the stock for the template. Have fun.
Gary
