I saw this list posted for a estate auction.
Mr. Knebel passed away quite suddenly.
This is my “I wish” list.
Looks like he had everything I could desire and more.
Cheers
M.Stehelin
STATIONARY TOOLS
Robland 2320 Panel Saw 10′ w/rolling table
Ritter 46 Spindle Double Line Born – double row 23 drill heads
Ritter Dowel Born – Process 32mm Dowel Construction Drill
Laguna P20 20″ Planer
Reliable Cutting Tools 609 24″ Template Clamp and 36″ Template Clamp
Craftsman 10″ Radial Arm Saw
Murphy Rodgers MRT-9H Dust Collector; 5 HP Twin Bag
Old Square Chisel Mortise
Coast to Coast 1 ½ HP Compressor
Campbell Hausfeld 3 ½ HP Compressor
Geometrics Vacuum Frame
60’s Shopsmith system
Solar 360 Battery Charger
Bench Grinder
Cedarberg 10 HP Rotary Phase Convertor Model 100
Mini Max SC3 Table Saw w/Biesmeyer T Square Fence & rolling table
Performax Super-max 37×2 dual drum Sander
Jet DC 1200 Dust Collector 2 hp-1ph w/hoses
Sears Roebuck 13″ Planer
Delta 31-780 Spindle Sander
James Taylor Clamp Rack on stand
Sears Craftsman Drill Press – Commercial Model 113
Blum Hinge Insertion Mini-press
JDS Air Filter Model 750ER
Rockwell Invieta Model 22550 12″ Planer
Makita 10″ sliding compound Miter Saw w/ wing Fence
Rockwell heavy duty Shaper w/ Delta 1/4 hp Power Feeder
Delta Sand Trap Downdraft table
Rockwell Unisaw w/Delta unifence 7 Beismeir blade finder
Delta 3/4 hp duster collecter
Delta 8″ Jointer
Ritter Model 701 Horizontal Edge Sander
Multico MCD Square Mortiser w/tilt table & enclosed stand
Multi Router Tennon Jig w/ templates
Sears Craftsman 12″ Band Saw on stand
DeWalt DW 788 Scroll Saw on stand
DeWalt 7790 12″ Radial Arm Saw – bench mounted
Delta 14″ Band Saw – bench model
Quincy Air Compressor 5 Hp 2 stage – cast iron
Cehisa Edge bander EP-2S w/power feeder
Ritter 13 Spindle Line Borrer
Geometrics Tip top Vacuum Frame Model 4364 on stand
Rockwell 12″ Bench Lathe
Boring Machine 2 Spindle Seeman-Cain Model 272
Rockler Router Table w/accessory kit
Atlas Shaper Model 3500
Powermatic Model 50 6″ Jointer
Tormek Supergird 2000 Wet Grinder
Makita 9820 Electric Sharpener
Rockwell 34-150 Unifeeder Power feeder
PORTABLE POWER TOOLS
Makita 2401B 10″ Miter Saw
Craftsman 6 HP 16 gal. Shop Vac
Rockwell 3″ x 21″ Belt Sander (cracked housing)
Rockwell #337 3×21 Belt Sander (poor shape)
Black & Decker 4×9 Orbital Sander
Taiwan 1 qt cup Spray Gun
Fitz Cup Spray Gun
Titan Milk House Heater 1500
FloTec 115 Volt Submersible Pump
Twin Bulb Work Light
Makita 7.2 Volt Cordless Drill
Bostitch CWC100 1hp Air Compressor
Hoffmann Edge Planer
Delta Sawbuck Frame & Trim Saw
Makita RF 1101 Router
Porter-Cable 75192 Router w/Betterley Coving Router Base
Rockwell 4676 Router
Porter-Cable 5372 Router
Metabo HO 883 Power Planer
Port-Cable Model 121 Oscillating Spindle Sander
Bosch 1582 VS Jig Saw
Makita DA 3000 R Angle Drill
Fein 6″ Orbital Sander w/Dust Collector system
Makita 9401 4″ Belt Sander
SkillSaw 77 7 1/4 Worm drive
Porter-Cable plunge Router Model 7539
Hitachi Model TR 12 ½ plunge Router – 3hp
Porter Cable Trim Router w/Betterly Sizing Router
Porter Cable Trim Router w/Betterly Miter Edge Base
Porter Cable Trim Router w/Inlay base
Porter Cable Trim Router w/Betterly Seaming Base
Porter Cable Trim Router w/Betterly Underscribe Base
Chamberlian Wax Master 1100
Makita B04510 Orbital Sander
3 Porter Cable 330 Orbital Sanders
Porter Cable 7334 Random Orbital Sander
Makita 9045B Finishing Sander
Fein MS x 636-1 Corner Sander
Porter Cable Drill 872 14.4v
Porter Cable 444 Profile Sander
Senco SFNII Finish Nailer
Duo-fast BN-6432 Finish Stapler
Bostitch T31 Pin Tacker
DeWalt DW 682 Biscuit Joiner
Virtulex CE96H Curved Surface Planer
DeWalt DW744 Portable Table Saw
DeWalt DW705 Miter Saw
Wagner CS4010 HVLP Spray Gun
Kreg Pocket Hole System
RotoZip Spiral Saw
HAND TOOLS
26 pc Wood Turning Chisel Set
Versa Ladder 6′ Folding Ladder
Cable Come-along
Eva 10″ Chimney Brush
Floor Stand Roller
24″ Framing Square
Auto Floor Creeper
55 Gal Barrel Hand Cart
6″ Digital Micrometer
2 Home K Double Mechanic Tool Chests
Johnson 24″ Level
Stanley Wrench/Socket/Tool Box
Nicron 43-Range Voltage Tester
Garrett Dial Micrometer & Magnet Base
Columbia Bench Vise, 3″ Vice
Eastwing Hatchet
Goldblat Corner Trowel
Taiwan 19″ Pipe Wrench
Pop Rivet Gun & Rivets
36″ Steel Straight Edge
Solid Surface Installation Tools & toolbox
Leigh Dovetail jigs
Porter Cable Dove Tail Jig w/ 2 extra templates
WoodTek Miter Trimmer
Precision Casework Assembly Jig
22 Large carving chisels, 7 small carving chisels, 7 carving knives, 1 wood mallet
Sharpening Stones – Diamond, 2 – Japan, 2 – Norton, 4 Jigs
6 Hammer Set
4 pc Marples Chisel Set, 6 pc Robert Sorby Chisel
Craftsman Toolbox – 2 sets Deep & Standard Socket, wrench, pliers, screwdrivers
Misc Wood Chisel 10 pcs.
Delta Magna Set
Numerous unmentioned tools
SAW BLADES & SHAPER CUTTERS
Numerous saw blades for the various machines
12″ x 72 Tooth Blade
12″ x 100 Tooth Blade
Saw Blade for Robland Panel Saw
Shaper Cutters Numbered: 8 LRN K-1450 & 1041
LRN K-1440, 1441, 1442, 1443, 1444, 1427, 1196, 1040
LRN H-3016, LRN Y-3016, LRN A-3069
9-Delta 93 ½ Bandsaw Blades
BITS, TOOLING & MISCELLANEOUS
Multico Mortising Chisel Set – 9 pcs, 2 Sharpeners
Multi Router Tooling – 27 pcs; Linear Digital Measuring; 7pc router bit set
Shaper Cutter; router bits; 10″ saw blades; shaper spindles; rub collars
Fact Cup “3rd Hand”, 2 “Little Hands”, 2 extension poles
4 “Trim Tree” Drying Racks
3 Sliding Miters for Rockwell Unisaw
3 pc Wood Turning Lathe Jaw Set
Craftsman Machine Vise
Ridgid Heavy Duty Pipe cutter, Threader & Dies
5 pc 7-ft bar clamps
2 Plastic Laminator Slitter; 7 rollers & clamps, Vituex T-78
16 pc Bessey Bar Clamp Set
10 pc Jorgensen Bar & Pipe Clamp
10 pc Jorgenson Bar & Pipe Clamp
8 pc Pony C-Clamp
2 pc Quick Grip Bar Clamp
9 pc Jorgenson Clamp Set
Castle Glue Shooter
4 pc Bessey Miter Clamp Set
Numerous Workbenches, Tables & Cabinets
Dozens of accessory items
Selection of hardwoods including Walnut, Mahogany, Elm, etc
Dang.. I think he went to TOOL Heaven.. I hope he is happy! Really...
I think it was Woodcraft who sold T-shirts a few years back saying -
HE WHO DIES WITH THE MOST TOOLS WINS
They could award this posthumously.
DR
DUDE - where and when is the sale!!!!
I can see it now...I come in the door from the auction:
"Hey, honey? I picked up a few things today at the auction...wanna come help me clean out the OTHER half of the garage?"
Jason (half a garage full of wood already)
You said that Mr. Knebel passed away ... this wouldn't be Mr. Ben Knebel of Shepherd Tools fame?
-Peter T.
