I am making a series of drawers using pinned rabbeted dovetails. What is your recommendation for either 1) pre-drilling the holes on the mating pieces and then pinning when the glue up happens or 2) gluing up the drawers and then match drilling the holes and pinning them after the fact.
Anna
Anna,
If you pre-drill the holes, the excess glue just squeezes out through the holes. It's a mess. Glue up, square the drawer, drill and pin after. It's simpler and easier. Have fun. Gary
Gary -
Thanks for your message. On the small drawers that method seems to be good. However, with the larger drawers, while my drill press has the ability to lower the table, the piece seems to move around a lot while I drill. I have it clamped pretty firmly on the bottom but I still get some vibration. any thoughts to stabilize the piece to make the holes more accurate?
Anna
Anna,
Your drill press table should be able to rotate around the column. Clamp on a piece of plywood or double stick tape a piece of plywood onto your drill press table but bigger than the table. Then slip your drawer box over this piece of plywood, rotate the table around so the joint is under the drill bit and drill away. It shouldn't flex too much if at all. If it does, put something underneath the drawer box to support it. The up in the air method you were using before is, as you say, too flexible, too much vibration. Get the drawer down onto the table somehow and then do your drilling.
Thanks. That should solve it. It worked on the small drawers and I will tackle the larger ones today.
Anna
