With a limited budget (around $700) which is best for a workshop producing small items possibly some kitchen units a table saw or a radial arm saw. The radial arm saw seems to be very flexible and better at crosscutting. How are the recent models of radial saw as far as safety? Ripping is better done on a table saw, I am interested in opinions from experienced users.
David,
I have both but if I could only have one it would be the table saw, no contest. My RAS is an old DeWalt which I made furniture and cabinets with till I got a TS. The table saw excels at ripping, the RS at crosscutting. But (with a TS sled) you can much easier, and safer, cross cut on a TS than you can rip on a RAS. One advantage of a RAS, though, is they can be placed against a wall, they don't take up as much floor space. GP
Spend your money on the best table saw you can afford.Build a sled for it and start work.Radial saws especially cheap ones are flexible.Thats their downfall they always need tuning
There was a long discussion about this in Knots last fall. Nearly everyone recommended a table saw. If you check the archives you can read the many reasons and compare them to your intended use.
David,
get a tablesaw.
it is always better to move the work through the machine than the machine through the work.
gk
start with a good table saw !! portable ones are fine with plastic saw horses. i have cut an old door to accept the saw in the past, when the portable saws first came out 30 years ago ,since then i have purchased the portable stand FOR MY FIRST SAW ( MAKITA 8 1/4" ) I WOULD PUT THE SAW AND STAND AGAINST MY DELTA UNI SAW FOR ACCURACY ANY DAY OF THE WEEK !! You will allso need a miter saw for crosscutting . You can also set it up using saw horses on a 2x 12 with a sub base so you can screw stops down if you have to gang cut material to the same dimension. whats your budget as far as dollars ? do you like the trade, how old are you ??
