I am building an addition to a home with many high end features; one of which is a 36″x96″ paint grade 4-panel interior passage door in a curved wall with a 7’9″ radius. The door will open into the room on the convex side of the wall. The custom door shop I’m ordering from has expressed concerns about their ability to make a stable door of this design. I may have to make it myself.
I’ve built standard frame and raised panel doors before but never a radiused one.
I’ve considered building up layers on a form with curved cauls; or brick-laying blocks and surfacing the blank with a router running on a track.
Trial and error on something this large would be extremely time-consuming unless I got it right the first time.
Any suggestions and stories of similar problems solved, materials used would be appreciated.
Thanks, Steve Doane
Dear Mr. Doane,
I'd recommend posting your question in our sister forum, Breaktime: http://forums.taunton.com/tp-breaktime?redirCnt=1
I asked editors around here and people suggested coopering, brick-laying blocks, or using bent-laminations for the panels, but since the panel is so large you might want to get some more input from the Breaktime people.
One editor raised concerns about shaping the tenons that hold the rails into the stiles. Cutting the angled mortises in the stiles and angled tenons in the rails might be tricky with such large parts.
Anyway, good luck with your project.
Gina
FineWoodworking.com
