When you are designing inset doors in cabinet construction what types of proportions do you use with regard to cabinet face frame width of rails and stiles along with inset door rail and stile width? For example if your face frames are say 2″ wide stock what would you use for an inset door frame stock width?
Ripmeister,
I asked the same question a few years ago, the response was not very specific because rail and stile dimensions are primarily design variables. In other words, within reason, whatever dimensions you'd like them to be and looks good to you. A 2" face frame on a single cabinet may have its look impacted by a much large rail and stile...but not so much if it's a wall of cabinets with 2" face frames. Personally, I try to configure the rail and stile width to the panel size so that there is a solid feel to the door at a minimun.
I use 2.25" stock for face frames and for door frames.
I think the size of both face frames and stiles and rails depend on the design you are trying to achieve. Typical manufactured cabinets and architect specified cabinetry often use 1 1/2" - 1 3/4" for both. There are always things to consider in addition to the design theme. Wide face frames will reduce the size of drawers in width. If you use side mounted slides with fillers behind, it will take more lumber and space. On inset doors, wider material may be prone to more movement. Stiles and frames that are 2 1/2" add up to 10" of wood per opening. Depending on species and conditions, this could cause fit problems. Obviously, you need to know how your hinges, slides and maybe pulls and knobs will mount. I always do a full scale layout to check all the relationships. It's also a good idea to do a full scale face drawing when looking at style. This will give you a visual of how things will balance and it will also give you a reference for cut lists and a general feeling about the construction.
Thanks for the responses. As I suspected the answer is, it depends. I'm going for a clean-lined Shakeresque look and was just curious as to whether people prefer cabinet and face frame stiles and rails that are like sized, different, use the golden ratio or some other relationship. As you said a full size drawing is best to help with the visualization. Thanks again
