looking at buying a raised panel set for a few cabinets I need to make.
will a PC 690 using light passes run a raised panel set or will it be too much strain on the router?
Unless you have a vertical panel raising set or a variable speed 690, your router spins too fast for the job you are contemplating.
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
-- Herbert Spencer (1891)
You * might * be able to reduce the work of the router by making a pass with your table saw first. I do this to reduce the amount of shavings.
So you make a (eg) 15 degree cut along the edges, then finish with the router. The router has to do much less work then.
You wouldn't believe the amount of shavings that come off a raised panel.
