I’m new at woodworking and going to start a project of building cherry cabinets.I have a Bosch 2hp router. It is said that if I use a 3″ dia. back cutting raised panel bit it will bog down when cutting? If so what are the largest dia. horizontal bits I can use. Should I use a vertical bit? The set up looks a lot easier with a horizontal bit.
I would run a verticle panel raiser or buy a shaper if your going to do more than a couple panels.
Not the best tool for the job... but...
Does your router have a variable speed control? If not, you SHOULD NOT attempt to use a 3" router bit. A 3" bit should be run at 10,000 to 12,000 RPM, max... not at the standard 20,000 RPM.
Vertical bits are a lot better for lower powered routers. You will get a better cut and there are a far-fewer safety concerns. Simply use a tall fence, burry the bit and creep-up on the final cut.
Yes a Bocsh 1671 2hp it has variable speed control but I guess I could use a vertical bit or table saw. I just made a jig for the table saw and will test tomorrow. It looks stright forward. I'll run some test cuts on the horizontal bit to see if the router would hold up. Thanks for your help.
You can definitely raise panels with a 2 hp router, as long as it has variable speed (which the Bosch does). But, do not use a bit with a back cutter. Get a panel raising bit, and set the speed to it's lowest setting. Take small bites, and save the final 1/16" for your final pass.
I raised panels with a 2 hp Porter Cable for 10 years before finally breaking down ($$$) and buying a shaper. You can relieve the back of the panel for fitting into the rails and stiles by using a dado blade in the table saw, or a rabbeting bit in the router, or a dozen or so other ways.
Go slow, and be safe. Make sure you use push tools, too, and keep your hands away from the cutter. I'm not trying to scare you, but I did have a hunk of wood come apart on me due to swirly grain. I'm glad my fingers weren't there when it happened. Push sticks are the answer.
Thanks for the excellent tips. I will try this method also on the test cuts. Again thanks for everyone's help.
Your Bosch is up to the task for some occasional raised panels. You need to take lighter passes. If you're about to do an entire kitchen, I'd opt for a bigger router, or possibly go with the vertical panel raiser but it can be harder to control the panel vertically than horizontally.
Thanks for the advise. I'm going to do some test cuts and take it slow.
