The article published in American woodworker (April 2001) advised to pre-finish the panels when building raised panel doors. Does pre-finish mean to stain or to stain and apply varnish, poly, etc? Appreciate your response. agriffee
I make it a habit to stain and apply the fininsh coats also. The reason being that with the seasonal changes in humidity the panels will expand and contract as the moisture levels rise and fall. This will be especially noticeable in northern climates when furnaces start to really dry out a house and the wood shrinks. If the panels are not finished prior to assembly an unfinished border will appear around the panel where it meets the stiles and rails.
Bill
I have found that it is best to pre-finish ( stain, dye, shellac, varnish, rub out etc.) whenever possible. Sometimes this is not very convenient, but in the end, it results in a superior finish. On raised panels this is doubly important for the reason noted above, and it is nearly impossible to effectively rub out the corners after assembly. I also pre-finish the molded edges of the stiles and rails to insure a good finish here also.
Thanks for your help. Yeah will take longer but no need to botch it up now. thanks again, agriffee
