I’m about to build my first raised panel doors and have a basic question. The panels will be about 9″ wide by 32″ long, red oak. I found some nice, straight 1 x 10 material for the panels. One reference that I looked at recommended cutting the stock into thirds, reversing the center piece, and gluing it back together to avoid warping. Is this a real concern with panels of this width, or should I just go ahead and make the panels?
Thanks for your help!
Forrest , If you have stock that's nice and flat and stable , by all means use it . Panels with none or a minimum of seams is a very desirable look . The beauty of frame and panel construction once the stable panel is captured by the frame little if any warpage occurs .
I take most of my panels down to 5/8" + or - then shape them . When you look at a panel door it is hard to tell how thick the panel is from the face . A lighter door and a flat panel .
good luck dusty
Absolutely not necessary. The problem that alternating growth rings is suposed to fix is a non issue. Make sure the wood is equalliberalized and go for it.
"alternating growth rings is a non issue"
Not by a long shot. His panel and door should be fine if the emc is low, about 6-9% roughly. If not, that red oak will move as one large panel instead several smaller, glued up pieces. The debate is not over,it's a matter of personal taste...
Edited 1/25/2006 2:02 pm ET by jackplane
jackplane ,
If the Red Oak is not adequately dry and stable , imo it will move whether you glue 3 pieces or keep it as one . It doesn't seem likely the 3 pieces could move independently after they are glued up . Why would you want them to ?
For a table top or other wood countertop that is not captured in a frame like a door panel is , alternating growth rings for glue up imo is more of an important factor in keeping the glue up flat .
regards dusty
as you mention, the panel will move if it's not dry enough. it's simply a matter of cupping as one panel, or cupping to a smaller degree among three glued up pieces.
best,
jp
Are you refering to expansion across the grain or cupping?
Thanks for your input, you've saved me a lot of time. I got all the rails and stiles done today. Next weekend I'll do the panels.
Forrest
Forrestgreen, I would rip the piece in half (releasing the tension it may be under) Then I would joint the two matching edges. Then All you have to do is glue them the same way.
-LMC
Release what tension? This "tension" you are refering to is ONLY released if the board is cut, otherwise the stress remains equalized. And that "tension" (more accurately described as stress) will cause crooking, not cupping or bowing. A 9" wide board is very unlikely to crook after jointed, only if it is reaction wood. Sorry if I sound like an a$$. It just kills me to hear these practices. They have never been accepted practices in woodworking.
I guess the only thing I'd add that hasn't been stated already is the orientation of the growth rings relative to the face of the board. Stated differently, quarter-sawn material will consistently remain flatter than slab-cut boards.
My personal experience echoes that of others. If the wood hasn't moved since its initial oversized machining (always a good practice, if one has the time...), its likely stable enough to bring down to its final dimension, edge machining, etc.
Marty
Assuming, and it's a critical assumption, that your material is at equilibrium moisture content and looks nice and flat, you can make the panels without cutting and reglueing. Plane it down as much as the raised profile will allow.
DR
Forrest,
One thing that may be helpful, is to plane the stock to slightly more than its final thickness, then sticker it, and let it rest for a couple days. If there is any inclination for it to cup or twist, you'll be able to correct it, and then plane to final thickness. I usually leave 1/8" for final planing, panel stock seldom moves more than that amt while it is "resting". No need to rip and rejoin.
Leave the panel stock full width, just try to take approximately the same amount off each face of the board when thicknessing. That will keep any stresses, if indeed there are any, in balance. And the easiest way to see that is by judging how much the boards that you cut up for the door frames or cabinet moved when you ripped them to width. If they didn't curl, twist, cup, bow, etc., then neither will the panels. If they do move a lot when cut then they may have, as suggested earlier, reaction wood, or have not been properly kiln dried. Oak is usually stable where as Maple seems to enjoy twisting just that little bit more than I generously allowed for when rough cutting. Especially when I don't have much extra.:-)
