is there a particular reason you don’t want to use solid stock for your rails and styles? – it would be easily worked with a router – – if you want to use the plywood, check out catalogs for profile bits for your router and make your own moulding….
Charlie, what you're probably looking for is called a 'bolection moulding' in British parlance. The edge has a rebate ~3/4" deep that encapsulates the fake stiles and rails, thus hiding the exposed plywood edges. This type of moulding sits proud of the plywood, and if you want to instal a panel, the opposite edge of the moulding is also suitably rebated.
I'm not sure where you would buy such a moulding in the US, apart from a millworkers supply, and I recall that Home Despot and Lowes wouldn't be likely sources for such a specialised profile. Slainte..
I appreciate your reply. I may have found a source I hope they send the catalog pretty quickly.
http://www.hprp.com/main/raised01.htm
Charlie
It should be apparent this is my first cabinet making project. The plywood rails and styles are already attached. The problem with taking so long to complete a project is you can change your mind. I started out with the idea of refacing the base cabinets like you do block paneling and as I got into it decided to replace the top cabinets with 42'' cabinets with raised panel doors. I am in a time crunch as I have promised to have the kichen complete by Christmas. I was looking for a short cut for the front and back of the base cabinets. I may have found the answer. http://www.hprp.com/main/raised01.htm
If this doesn't work out, I will take your suggestion and make my own. I appreciate your response.
Charlie
PS I stayed up half the night reading different sections and was particularly interested about hand planing. This afternoon was happly spent planing the panels that I had already glued up.
very good - - a similar hand planing technique can be used to create rails and styles for your next project - - if you have a table saw (and your handplane), you can create your own mouldings if the company in your link doesn't work out for some reason - they won't be ogee'd, but attractive and presentable - - post back if Hyde Park doesn't work out - good luck, lots of help on this forum in regards to questions you may have - DOUD
I have a table saw, router table with router bits, and a compound mitre saw and a lot of maple boards. What I don't have is experience and time. By the time I finish this project I will have more experience and will have had a good time. Ha Ha.
Thanks David,
Charlie
