ANY TIPS ON HOW I CAN CUT RAISED PANELS ON A TABLE SAW?
http://www.taunton.com/finehomebuilding/how-to/departments/building-skills/making-a-raised-panel-shaker-cabinet-door-on-a-tablesaw.aspx
Rev Ted,
I like the way that he did it in that article, but I like to rabbet the back of my panels before I raise the front of them so they will sit flush with the rails and stiles. Everyone has his/her own way of doing things, I guess.
Good day,Harry
Following the path of least resistance makes rivers and men crooked.
Thanks for the reply and the info. It was pretty much what i thought but i had forgotten the angle of the cut and i will use a dowel joint for the frame instead of the tenon. Thanks so much!
The link that was already posted gives a pretty good overview of how to do it. But I need to ask - why not use a router table and panel raising bits? Even if you don't have a router table, you could improvise one for this job in half an hour. In my opinion, the TS method will work, but with a router you'll have more accuracy, less sanding, and safer work.
David Ring
David,
I'm sure this has come up many times before but I wonder how well raised panel router bits work if you don't have a powerful router? Can you get away with multiple passes and light cuts?
What would you recommend as a minimum Hp for a table based router?
You absolutely can get away with taking multiple passes. For years all I had was a PC 690 router, and I used it with the large panel-raising bits as well as the common rail and stile sets. I made more than a few kitchens with that router alone.
Stepping up to the 3HP class is great, but not justified if you're only doing the occasional few doors. At some point it became obvious to me that even that bigger router wasn't the right tool, so we then stepped up to a shaper. But keep in mind - we make at least 15-20 doors every week.
You can make excellent doors with a 1 HP router if you take your time.
regards,David Ring
Thanks.
I have a Hitachi M12 router in a table, not the variable speed one. With the Router Raizer it should allow me to make multiple passes quite easily.
Bob,
The router bit people designed the vertical panel raising bit to be used on smaller routers. They are generally less than 1-1/2" diameter.Chris @ http://www.flairwoodwork.spaces.live.com
