Does anyone have a rule of thumb on what size rare earth magnet to use in relation to the size of a cabinet door so the door stays shut but doesn’t require effort to open it? Assume the magnet will be in a steel cup holder to maximize its holding power.
rare earth magnets
I've only used small ones for cabinet latches. Even the small ones have significant holding power. If you need to reduce the "hold", try deepening the recess a hair.
rare earth magnets
Does small mean 1/2" or 3/8" or 1/4"? What's the appoximate size of the cabinet door?
"small" defined
I've mostly used 1/4" ones for this, but large, heavy doors might require something larger.
use two up and down
small is fine. They have great holding power. Do a mock up and test. I use two. One in the bottom or top of the door depending on application with a second in the oposing face. Use a fortsnerbit to recess and I cover with a plug and they are not visible. ONE WARNING: use a sharpie pen to park the pos/neg sides so when you put them in you don't wind up with a ++/-- situation and the door won't close (don't ask how i know). They work great and they are invisible. I hate the metal plate ones I just think they look tacky. Small ones are fine remember you just want the door to stay closed and not need a pry bar to open it.
Good tip on marking the poles. Question -- Do they have to be perfectly aligned to grab?
K&J magnetics has pull force calcuated for all the differnt magnets and how they are used.
www.kjmagnetics.com/
I have applied thin veneer to cover the magnet and steel washer leaving no visible catch. Get a 3/8 inch ball magnet and use it to find the nails in drywall as a stud finder, leaves no marks and doesn't need batteries.
Steve Duncan (cabinetmaker)
http://www.steveduncan.com
rare earth magnets solution
Thanks for all your comments. I used a single 1/2" magnet in a 5/8" steel cup going against a thin steel plate to close a cabinet door that's 21"x30" made out of fiberboard. The hold is just slightly more than I would have liked (although it's ok) so I may put a piece of double sided tape on the plate to reduce the hold strength.
Wouldn't it be useful for FWW to generate a little table showing magnet size, door size and type of wood (i.e., indicating its weight)? It would take away a lot of guesswork.
