Has anyone ever made a ravioli rolling pin? If so, how did you go about it? They’re really not terribly expensive items to buy but I enjoy making the things I use so …
Mark
Mark
Mark, Raviolis can't roll. Meatballs roll. Motzoh balls too.
But seriously, I think the rollers you refer to are insized with an automatically programed turnip shaped carving router bit.
All the sections are identical and repetitave.
You might just mark out a plain rolling pin and carve out hand made indivdual shapes using a hand held Dremel motor tool with a carving bit. Stein.
To cut out the indivdual raviolis, use a pie crust crimper or a pizza wheel.
Mark, I think you've inadvertently added another project to my to-do list. My wife's family will get together and make ravioli by the hundreds for Christmas dinner and freezing, so that everyone can take some home for later. I never knew there was such a thing as a ravioli rolling pin, though.
I did a search on Google. From the pictures I found, my approach would be (will be?) something like this: Turn a rolling pin, making sure the barrel is a consistent diameter, and the barrel length is a whole multiple of the ravioli size. Make a carboard template for the recess, with shoulders to register against the diameter of the barrel, and turn the recesses. If you have a lathe with a indexing head, make a carriage for your router, so that you can mill grooves for the splines with a straight bit and collar. Mill the splines, and glue them in with epoxy (or something else that will handle water).
Hopefully that makes sense.
Froed
