I have a Grizzly 14″ bandsaw with a 3/8″ blade. Either timberwolf or carter, I forget.
I am having troubel resawing a piece of maple roughly 2″ thick and 8″ wide. When I start to cut the blade pushes back and to the right of the guide wheel and chatters. What am I doing wrong? The maple is a piece given to me from a tree blown down and was rough sawn ~10 years ago. Any suggestions?
If you aren't sure what kind of blade you have, there is a real good chance it's old and dull. Try a new blade made for redrawing. I have great results with a 1/2 inch woodslicer from Highland.
If you are using a guide it could be that the guide and the blade are not parallel. Start a cut using the guide and stop the saw and see if the rear of the blade is centered in the kerf.
Not dull I just did not remember which my 3/8 was. It has not been used much and worked great on sawing out a 5" thick bowl blank. Thanks for you thoughts.
I will check the kerf, thanks.
I agree with John c2 woodslicer 3tpi 1/2 inch blade would do the job nicely and by the way there are excellent videos on resharpening bandsaw blades and I have had great results with it ,you may want to give it a try - here’s a link to the YouTube video by Brian Proctor that I found worked well https://youtu.be/9yhQiKOBx7E
Layne
If waste isn’t a major concern It’s also very helpful to use the table saw to hog out some of the kerf before using the bandsaw.
Ripping a groove maybe an inch or so deep on both edges can lighten the load on the bandsaw and can help the blade track better.
I would check a number of things.
1. Blade drift: To a partial test cut on some wood and than stop the saw with it partially cut and still around the blade. The kerf should be parallel to the blade. If not, adjust the fence and test cut until it is.
2. Is the blade suitable for resawing? An 8" board will need a blade with a lot of space in the gullets to evacuate the sawdust. The suggestion for a Woodslicer is a good one.
3. Slow and easy wins this race. Take your time and let the blade do its work. If you force it, the blade will wander and once that starts there's no way to recover.
How far back is it moving? Your thrust bearing or surface should only be about the thickness of a piece of paper away. If the blade can travel back enough your guides may ruin your tooth set.
I agree that for an 8" height a 2-3 TPI blade is about the most I would want to use. An exception might be a Woodslicer with a very slow feed rate if I were after a very narrow kerf and a very smooth cut. Carbide blades are another discussion but, it doesn't sound like they would apply to this thread.
In cdesautels' post 2 above this one, his item #1 probably meant to say that the kerf should be parallel to the fence, not the blade.
You could be looking at grain drift, where the blade wants to follow the grain, more prone to happen with either inadequate tension, dull blade, or not aligned for drift.
A new blade and realignment usually solves the problem.
Re: MJ's post.
No, I meant parallel to the blade. On a properly tuned saw the kerf and the fence will be more or less parallel in the end but may not be square to the table. To adjust for drift you have to make the fence comply with what the blade wants to do. Of course this means that you need a fence that can be adjusted this way. Good fences can do this as a matter of course. If you don't have one, you'll find re-sawing challenging.
If your guide is not parallel/square with the table, how do you get to use the slots in the table using a miter gauge or a sled to resaw logs? Everything needs to line up, fence, table and blade.
I thought that slot in the table was to get sawdust out of the way. And for holding pencils
They work fine for that also, otherwise I would always look for my pencils . If the guide and table are not square to each other, that also bring alignment problems when you tilt the table, you end up with a compound angle between the guide and blade which makes resawing odd.
Maybe check out this video on setup. I followed Alex’s directions and my 14 Delta cuts to capacity without any difficulty.
https://youtu.be/wGbZqWac0jU
Cheers,
Check out this video from Ethan and a video he has on bandsaw drift when resawing. https://m.youtube.com/watch?v=W8k0_HP8srQ
You’ll be surprised at what he does with a loose and maladjusted blade.
