OK, You guys dont seem to understand my message. I tried all my local sources as well as McFeeley and several other national sources. It seems that screws that fit ALL my requirements do not exist, or at least not to my knowledge. If you don’t believe me, try for yourself. I would love to say I was wrong, but as yet I haven’t found them(#6 1 1/4 steel flat head phillips drive wood screws with brass finish). It seems that the brass finish is the rub and it’s necessary in this case because these screws as I am using them are decorative as well as functional. I dont really want to buy a bigillion of them by special order but it seems like thats what I’m going to have to do. Thanks anyway
How many do you need? Have you considered plating your own? Electroplating in small quantities is not technically difficult.
j,
I replied to your original post.
Here's a US supplier - google term was brass plated screw (no inverted commas)
They're slotted head, not phillips drive but
http://www.crafters-mart.com/Hardware/Brass_Plated_Screws/brass_plated_screws.html
The google search also gave many more, but these guys probably could supply.
Cheers and happy Xmas,
eddie
buy brass screws.
Where are you located?
John
Change your requirements.
PlaneWood
JMuir,
I think part of your problem is that a #6 by 1 1/4 screw is something of an odd ball, very long for its diameter.
It is hard to picture an application where a screw of that size would be that much stronger than a commonly available #6 by 3/4, if the shorter screw was properly installed. A long #6 would be relatively weak and likely to shear off before it was fully seated unless an overly large pilot hole was drilled and that would reduce the screws holding power to around the value for a 3/4 inch long screw in a smaller pilot hole.
If you need more holding power you are better off increasing the screw's diameter rather than its length, if the hardware you are attaching will allow it. What are you trying to attach to what base material with #6 by 1 1/4 screws? There may be a better alternative.
John W.
Edited 12/23/2003 9:54:49 AM ET by JohnW
Edited 12/23/2003 10:03:40 AM ET by JohnW
Contact Kenneth G. Lilly Fasteners, 302-366-7640. They carry a greater variety of screws and fasteners than anyone I've ever dealt with. If they don't happen to have exactly what you want, they probably can tell you if/where it's available.
Another option is to use a steel screw to "do the work" and then replace it with a brass screw for final assembly.
John
John,
How's retirement going? Hopefully you're finding plenty of time to use some of that boat load of wood. The one-piece walnut frame turned out beatifully, really awesome wood. I'm still saving the rest of the walnut for something special.
Back on the subject of screws I use bunged combi-drive SuperSinkers whenever possible. If I need to use brass screws for show the Fuller tapered drill/countersinks allow driving brass screws in all but the hardest wood without doing double work. I haven't bought a set yet, but gunsmith's screwdrivers really make a difference with slotted screws. You can order them from Brownell's http://www.brownells.com/aspx/NS/store/ProductDetail.aspx?p=423&title=MAGNA-TIP%7e+UPDATE+SETJohn O'Connell - JKO Handcrafted Woodworking
John,
Retirement is going just fine. I spent the bulk of the last 3 months in Berkeley helping remodel my son's house. The wood pile is slowly shrinking, mostly because I've sold some ... the woodworking has been on hold while the work was going on.
Could you send a pic of the frame in walnut you did? My personal e-mail is
[email protected]
John
