would anyone happen to know how to remove dried yellow glue from the teeth on Bessey clamps
Mlw13,
I tried something new the other day to clean up my cabinet clamps...maybe it would work for you. I scraped off the glue with an old chisel and then applied a 50/50 mixture of vinegar and mineral spirits (turps might have been better) and worked that with 000 steel wool. A quarter cup of each was plenty of product..good luck
I used the wire brush on my bench grinder, though it might chew up the teeth if it happened too often.
KDM
The Bill of Rights
December 15 1791
NRA Endowment Member
LEAA Life Member
CRPA Member
I use a X-ACTO knife.. Pops it right out!
The last time I had to clean up several, after a semester of abuse by students, I knocked off the easy clumps with a handled scraper; to remove the tenacious bits, I used a brass brush and scotchbrite pads after subjecting the clamp surface to the output of a clothing steamer with distilled water and vinegar in the reservoir.
-Jazzdogg-
after a semester of abuse by students..
I would think part of their grade should be tool up-keep!
I genereally tap the glue with a hammer after fully dry, and because it is basically brittle, it just chips or falls right off.
Alan
http://www.alanturnerfurnituremaker.com
