I’m a rank amateur who needs advice from someone who really knows about refinishing old furniture. What’s the best brand of shellac to use for french polish? Am I even on the right track? What’s antique oil?
we respect honest declarations like your opening statement--you deserve a good answer.
the brand doesn't matter--what does is that you mix your own from dry shellac flakes, because shellac has a limited shelf life.
antique oil is a marketing term that one manufacturer (minwax) uses for one of their products (probably boiled linseed oil mixed with paint thinners, but i'm not sure).
*Mixing shellac flakes with alcohol produces the best french polish, however I have had success with canned shellac, check the date on the bottom and use only fresh shellac. Mix it with at least 50% alcohol. Moses T's St. John's Oil closely approximates 'Antique Oil', an old term for this type of finish. Available from ilovewood.comStephen
*Mr. Sheperds reply is quite correct. Over the years I have repaired, restored, and reproduced a number of pieces of furnature using french polish as the finish. I find technique and material used in the application far more important than the shellac. Let me recomend two books from my library that I believe will give you the step-by-step help that you need if this is your first attempt.Finishes and Finishing Techniques, one of the Best of Fine Woodworking books has an article by George Frank, "French Polishing, Applying the ultimate finish". Better yet, however, is the book Clissic Finishing Techniques by Sam Allen. Mr. Allen details several french polishing techniques in a way that I believe will be easier for the beginner to grasp.Good luck. Take your time and enjoy the results.Steve Mickley
