I want to be able to finish furniture and cabinets, and also do interior trim in houses. All the way from stains and clearcoats to latex finishes.
Can you recommend me a gun-pot-compressor combo that is right for me?
I would not recommend spraying latex with a HVLP rig. The tip size needs to be about the same as a water hose.
Sounds to me what you really need is an airless rig. My airless rig (.5 GPM) sprays stains, polys and lacquers very nicely.
__________________________________________________________
Michael in San Jose
Freedom from mental disturbance is the very most for which one can hope.
Epicurus (341-270 BCE)
Checck out accuspray at http://www.compliantspraysystems.com I have a accuspray and love it.
Darkworksite4:
Gancho agarrador izquierdo americano pasado que la bandera antes de usted sale
I have a Fuji 4 stage that does great and is portable. When you say you want to spray trim, I assume you mean oil. I have used it to paint doors, and built-ins more than anything else and the finish is better than an airless. If you are thinking of using it with latex, I recomend an airless. When I have to spray a cabinet with latex I use an airless and thin the paint with about 15 percent water. To use HVLP you will have to thin more than 20 % and the finish looks bad, pluss I worry that the paint will fail as the instructions say not to add more than 10 %. Even thinned at 20% most turbines will not atomize as well as an airless.
The consensus here, and on other sites as well, is that conversion guns are superior for finishing.
I just got the wagner setup-convrsion gun, cup, and 2.5 gal pot, with needles.caps to do stain, lacquer, poly, latex. Works great on the lacquer, stain & poly. Haven't had a chance to try the latex yet- no latex requirements yet.
