Greetings! I’ve been working on a new bench, and as I am a novice to mediocre woodworker who has a penchant for “learning from my mistakes,” I’ve decided to make a low-cost workbench that I can cut my teeth on for a while while I learn the craft. Needless to say, there’s a lot of 2×4’s and plywood involved.
I went online and bought me the biggest record quick-release I could find (53E), and I bolted it up to the bottom of my bench, after cutting a mortise into the skirt to accept the unmovable jaw (I plan on wrapping the whole thing in 4/4 maple, covering the unmovable face later), when I notice that the casting angles backward from bottom to top. This makes it very difficult to mount it flush to that maple skirt I plan on adding later.
I’ve read Scott Landis’s book on the subject several times, and nowhere is this trait mentioned. I’ve also scoured the internet for examples of how people mounted their vises and I havn’t heard mention of this problem. Am I losing my mind?
I wonder if I need to shim out the front mounting holes to make the face flat to the skirt. Am I on the right track?
I know what you are talking about, and yes, they are slightly sprung towards each other. I guess what I am talking about is that the rear jaw's surface (the one that sits next to the wooden cheek and comes in contact with the work) doesn't seem to be 90 deg to the mounting surface (the four bolt holes / slots) or parallel to the rear part of that casting. Is this normal? (pardon the pun) It seems to be about 87 to 88 degrees to the mounting surface.
This sounds wrong. The inside faces of each jaw should either be 90 degrees to the bench surface or cant in towards the work. I think usually the back jaw is set to 90 degrees for easier mounting and the outside jaw is canted in. Also, the back jaw is supported by the bench top and does not need to be canted. I sounds as though your back jaw cants away from the work. If that is the case, send it back.
Todd
I got a response from Record, which seems to clear things up. I'll attach the text:
Hope this helps anyone else that might be as confused as I was . . .
Bill
Bill,
Who did you talk to at Record? I have two of the same size vice that I both a few months back. The faces on both vices have a great deal of cup to them so that when closed, they only clamp on the sides, not accros the width of the vice. I have had problems with a record number 7 plane also. American Tool sent three different planes and not one of them met their specification of flatness within 0.003 inches on the sole. They (Barry Pope, Sr. Product Manager for Record) now tell me that they will do nothing more. I will be contacting the former head of Americal Tool as well as the CEO of Rubbermaid (who just bought out American Tool) to pursue this furhter. In Texas, what they have done is in violation of several laws.
Also, forget about Tool Crib of the North. When I found that I had a problem with these vices, I contacted them to have them picked up on a call tag for a refund. They said that since it was past 30 days since I had received them, I would have to ship the vices back to Tool Crib at my cost. They told me to go to the manufacturer with my problem. Since I was not able to get any help on the plane, I wonder what my chances are on the vices. UPS says this will cost $54.00 to ship both back. Maybe your contact can be of some assistance. If not, I will let everyone know to stay away from Record products.
John
