i have 2,000 ft of casing that needs to be recut. the back has been cut so that of the 4 inch width about 1 3/4 inch touches a flat surface. a local millwork shop said they had difficulty achieving a consistent feed rate when recutting moulding that did not have a flat back.
will i have any difficulty recutting the moulding on a powermatic pm15 planer/moulder?
thanks for any advice!
Try a 3'-0" length, if you have a problem try a temparary filler strip under the casing.If that works, fasten the strip somehow,maybe on a carry board that clamps to the tables.
mike
thanks much. could certaintly attach casing temporarily to a carrying board.
