I am recycling some 2 1/4 x 3/4 Jatoba hardwood flooring. It was removed from a residence where it had been installed about 5 years ago. The wood was carefully removed and the old nails ground down on the back side. The original floor was finished on site with what appears to be a commercial floor finish – probably glitza (sp?). My question is whether to re-install the flooring before sanding off the old finish or to run the boards through a planer before installing. I have noticed up to a 1/16 difference in thickness on the existing boards – probably due to sanding differences when first installed. I have about 1600 sq ft – that’s a lot of planing, but my concern is that if I intall the flooring and then sand I will end up with high points where the boards are thicker unless I get very aggressive with a floor belt sander – which is never easy to use. Your comments and suggestions are welcome!
Jay
Dear poppa,
I think your question about hardwood flooring would be better for the folks at Fine Homebuilding magazine. You may want to consider posting the question on their version of Knots, called Breaktime. Here's a link:
http://forums.taunton.com/tp-breaktime
Good luck,
David Heim
Managing Editor
FineWoodworking.Com
Thanks for the direction - done.
