I’m finishing a red oak poster bed. Want it to be “medium” brown color. Am considering several coats of boiled linseed followed by several coats of polyurethane varnish. Not sure if I should use a sanding sealer first. And what type of varnish would be best. Any suggestions.
If you'd like to use boiled linseed oil on the red oak, be sure and wipe it dry after you apply it and again about 15 minutes later. I would check it again after that too.
Red oak is so porous that it will continue to ' bleed out" oil, especially if you tend to flood it on.
Let the BLO dry a few days before proceeding.
Personally, I would apply a thin coat of Seal Coat by Zinseer (blonde shellac) over the BLO before varnishing. You can brush or pad this product on. Just be aware that it does dry quickly.
Give it a light sanding with 220 or 320 as required prior to varnishing to give the surface some tooth. Clean the surface well with a cloth to remove the dust and you can then proceed with topcoats.
As far as a varnish; there are fast drying wipe on urethane's that are simple to use, if that is the route you want to go.
There are also the brushing varnishes that can be thinned down with mineral spirits and used as a wiping varnish.
One other suggestion; consider trying Watelox brand varnish. It is a thin wiping varnish. You could skip the BLO and urethane and simply use this product by itself. It comes in Gloss, Satin and Original. All are very easy to use and would make your finishing almost fool proof.
Good luck.
Peter
