Is there anything I can apply to Red Oak to get the “red” out of it? I tried house hold bleach full strength and that doesn’t work.
Paul
Paul
There are some two part wood bleaches on the market. You can find it at most paint stores, and some big-box stores.
Oak doesn't react well to chlorine bleach, but rather to peroxide and NaOH mix. You can get ready-to-use two part bleach or buy the chemicals and make it up yourself.
David Ring
Paul
Once you have applied the bleach solution and it has done its job, you need to neutralize the reaction by washing the wood with a solution of 1 part white vinegar to 2 parts water. JL
Here is link to wood bleach techniques and chemicals.
http://antiquerestorers.com/Articles/jeff/using_wood_bleach.htm
You might try a bit of green dye if you don't mind the wood getting a little browner.
