What is the best process to refinish a cherry hutch. The reason being is that the joint on top of the door is not flush (probably moisture content caused displacement). I was planning to sand down the defect then apply 1)Sanding Sealer 2)Dark Red Mahogany Finish and 3)Clear Gloss Lacquer.
Does this process sound correct. Please advise, your help is appreciated. In other words, what is the best way to solve this problem?
Jacob
This problem might become smaller with a weather change, check wiht the customer to see if this is the case? If it's permanent,sand flush and finish appropiately. Good luck.
