A have a number of classic oak pieces that I have built over the years and finished with several coats of Natural Watco Danish Oil and furniture wax. I have moved into an old (circa 1900)house and want to darken the furniture to match the trim and era. The pieces are in good condition, so I don’t want to have to strip them. Is there a way to prepare the surfaces to take the wax off and make the wood accept darker oil, without creating a blotchy mess?
Mineral spirits will remove the wax. Just keep changing the cloth or use paper towels. Go over it two or three times. That removes the wax.
Now, Watco contains a resin (vanish) that hardens and is not going to be dissolved by the mineral spirits. This resin will prevent absorbsion of any other stain to a significant extent. You can try using a gray scotchbrite pad to slightly cut the resin and try a tinted Watco on a small spot without wiping it off and see how you like the color. Briwax also makes tinted waxes and you can give that a try. Finally, you can get some toner and spray that on but now you are applying a film finish and you will need to overcoat it with a clear finish.
Final choice is to sand and refinish.
*Try Lilly (was Guardsman) Warm Brown Glaze. This is a material that's made to go between layers of finish. It's like a very thick stain with a bit of binders. Strip the was as described in prior note, then apply the glaze, let dry 24 hours and top coat. You apply the glaze with a wipe on - wipe off application. It's covered in most of the current finishing technique books -- Jewitt, Nobel, and Flexner. If you don't get the effect you want, wipe it all off with a thinner-soaked rag and start over.Watco also makes tinted or dyed Danish Oils, but I have only used these once, so I cannot comment on how it might work. Others might have experience in this.You should experiment a little first to make sure you get the desired effect. You might want to add a sealer coat of shellac over the watco and under the glaze.
