Refinishing an Old Chair – Advice on My Planned Step by Step
Hi all …
I’m new to refinishing furniture and recently I went to the local used furniture place and picked up what I think is an interesting chair. I want this to be a learning experience and it is important for me to get the process right.
So far, I’ve managed to take it apart and even got down to re-gluing a broken part.
So now for my plan of action:
(1) Determine Wood Type:
Find out what type of wood I’m dealing with. Since it is as hard as heck and really doesn’t sand easily, is close to white in colour and I can see the rings (terminology?) … Maple!
(2) Sand Until Smooth:
Since it is painted(?) across the grain and quite scratched, I am sanding it starting with 80 grit and working up to 220 using a 1/4″ sheet sander, sanding sponge, micro-abrasive pads and hand sanding. I interchange whichever sanding method I use based on how frustrated I become with the particular method I am using.
(3) Fill Dents, Pores and Deep Scratches:
For the dents and scratches I want to use Elmer’s Wood Filler and for the pores (I’m assuming there are pores requiring filling) I plan on using 4F Pumice.
(4) Light Finish Sanding;
A once over with 320 grit.
(5) Add Colour:
Since I want it to be black and shiny I was thinking of painting it with latex enamel priming first, sanding with 220, followed by sanding with 320 after each of 2 coats of black.
(6) Finishing:
I was thinking of putting on three or more coats of Varathane Diamond Wood Finish (since I have some) and Laquer doesn’t go over water based finishes.
I have a photo below of the chair as bought and a close up of a sanded area to help determine wood type.
Whatever advice anyone want to give I’m all ears.
Bob
suggest reposting
I'd suggest that you repost this in the Finishing section, Bob. You're more likely to get advice there on refinishing the chair.
Reposted
Thanks Ralph, moved to a more appropriate forum.
Bob
Refinish
It's a lot to read but a couple of things that I would do different. First stripping with paint remover is better than sanding off or down the finish. So strip it and follow up with thinners to clean surface. Sandpaper but start with 150 up to 180 - that's rough enough. Buy a black lacquer primer in the spray can and spray evenly all wood surfaces. Fill nicks, and I would go to a satin black lacquer in a spray can for my color and that will also serve as a finish.
I'm guessing you're changing the fabric so it will be taken off before the work begins - I'm not sure if those fabric covered pieces can be unscrewed - you'll have to check and that will determine how you work.
SA
