We just purchased a house that was built in the 70’s, and the living room has a knotty pine ceiling (which is nice), but the beams running throuhg it have been painted dark brown. How can I refinish them to look decent? Strip? Paint over it? Please advise, anyone who can help. We want to maintain a rustic appeal since it is in the Northwoods.
attack them with a good quality stiff wire brush and see how tightly the paint is attached....
Re: the painted wood beams...I'm afraid because the wood is so rough that the paint is way in the slivers of the wood and knots.
Not sure how old this post is..
Just a warning... Ceiling collect ALOT of smoke and oils.. I would recommend a good scrub brush, and clean with soap and water! Be sure to rinse it well..
I was in a hurry once painting beams.. I was staining and just thought it wasn't working well.. Cleaned the beams and everything went well after that.
Edit.. painting beams.. I was staining .. Well, whatever..
Edited 3/29/2005 1:48 pm ET by Will George
sandblaster
I'd go at it with an electric hand planer. No messy chemicals or sand sprayed everywhere. The planer marks will look rustic, only a little different than the roughsawn look. Bill
Some suggestions:
1. Paint over the brown with something light.
2. Remove the paint, but this will probably require either planing or sanding the boards down. Lots of work and lots of dust ... and maybe some lead paint issues.
3. Use thin, pine veneer to cover up the outside of the beams. You could get 3/4" stock and use it, although it'll be finished (sanded) to a level that is probably not in keeping with the current rough finish. It'd probably be better to buy rough stock, 4/4 in size, and rip it down the middle. That'd double your yield and give you the rough look you currently have, and the "veneer" would be about 3/8" thick ... not too bad.
John
Edited 4/1/2005 10:33 am ET by johnhardy
