Hello all,
First time in the Knots forum. I hope to learn volumes. I am working on refinishing dining room chairs in the “off season” of winter and I have some refinishing questions. The chairs have turned spindles and I would like an easy way to remove the old stain. I have refinished many pieces of furniture and have tried many different strippers ( ex. Prostrip II, Citristrip, etc. ) with mixed results. If the work is simply stained I usually just try sanding the wood until bare. If there is a copious amount of paint and/or stain on the project I will try a stripper then sand to finish.
I was curious is there was a product that would work well with the spindles on these chairs. I have tried Dremel tools and drill adapters to get into the grooves on the spindles again with mixed results. I have also thought about having the chairs dipped but I’m not making that much on this to begin with and that would be cost prohibitive. Any suggestions?
Hi kc ,
On the spindles you can try your chemical stripper , by brushing it on a good coat let it work until you see the finish lifting and such , what I have done is used a glove with steel wool to work the finish and stripper off the spindles . Depending on the specifics of the stripper you are using lacquer thinner can be used with the steel wool and a wet thinner rag to rinse the spindles clean . Sanding them clean usually is not an option .
good luck dusty
Thanks for the input. I am quickly realizing that sanding the spindles is not an time friendly option. Any thoughts on which chemical stripper is the best?
I sent PETA steaks for Christmas.
Edited 2/10/2005 12:32 am ET by kcbuilder
kc ,
The very best I know of is made by BENCO , there are several types a thin and a thicker type and it may be marketed under several different brand names in different parts of the country . Bix is another name it has been sold as. Do a search on Benco stripper and you may find the nearest supplier . Methleyne Chloride is the active ingredient and this is some hot stuff literally it can be heated to make it even more effective . Follow all safety guidelines and by all means use proper ventilation and safety precautions .
dusty
I really hate to hear about sanding to remove finish. It will remove any sort of patina the wood has gained over the years. To remove finish from spindles get one of the brass brushes to scrub around the turnings. I also use 00 steel wool to remove the paint sludge.Gretchen
Here are three thoughts on the issues you pose:
1) First, if the chairs have a dark stain, it is unlikely that you will be able to remove all the stain residue, no matter what type of stripper you use. Generally, I strip what I can, sand lightly, and restain with a color that is perhaps lighter than the original, but compatible in hue.
You could try to remove more stain, if you choose, by use two lightening agents that are standard -- oxalic acid and/or a two part wood bleach.
2) For the spindles, brass brushes, steel wool, or Scotch Brite pads are your best alternatives. If you have access to them, planer shavings also work well.
3) Which stripper. I have never found any of the "safe" strippers to be consistently effective. I recommend anything with methylene chloride -- but enough of that ingredient so that the stripper is labeled "nonflammable." I use a product (from my local paint store) made by Day, called "Marine Strip."
Paint stores are more likely to carry these more heavy duty strippers than home centers.
