I’m new here. Been reading and enjoying the forum for a while but just registered to join in. I’m very impressed with the help everyone gives each other. The pollitical debates are great too! Hope you’ll bear with me as I learn the ropes.
Built a set of pine cabinets some twenty years ago, stained them with Minwax (Puritan pine), and then rubbed in a couple coats of thinned poly – probably Zip Guard.
There is little sheen left, here and there some crusted remains from me “helping” my wife cook, and a bit of what appears to be water damage. (sort of bleached out area running up and down with the grain) All in all, they look better than I just described. I’d like to clean them and put a coat or two of protection back on. Does aynone know how I should do this? Can I do it?
Fred
Fred - I'd pretty much follow your plan if they were my cabinets.
I give them a good cleaning with soapy water then another cleaning with mineral spirits or naptha to get rid of any remaining oily (greasy) dirt. Then sand all the surface lightly with 320 grit to remove the surface of the old finish. Then wipe on a coat of the stain, just to renew the color. Let the stain dry completely (odor free) and then apply a few coats of poly. The cabinets will look like new (or very well cared for at least)!
Paul
F'burg, VA
Thanks for answering, Paul.
I've been chicken to try the coat of stain, thinking it might show up blotchy. Good to hear someone thinks it's the way to go.
Have you had any experience with the polyurethane gels? The brand I have is Mastercraft. Thinking of using that after the stain. It sure goes on easy, and looks great on a new door I finished. Time will tell on wear.
I've pretty well run out of excuses and have to "get at it".
Fred - I haven't tried any of the gel poly. Do they make it a gel so it's easier to apply on the sides without making a mess? I haven't paid too much attention and was wondering what the strong points of a gel finish are over a regular poly/varnish?
As long as you don't sand through the old finish, the new coat of stain will not soak in and blotch - but you have to be sure it's good and dry before you apply the poly so it won't smear. The binder in the Minwax is strong once the stain dries - you'd have to use lacquer thinner or stripper to get it off.
Paul
F'burg, VA
Paul,
According to the literature on the Mastercraft can, the benefits of the poly gel finishes are no drips, runs, or overlapping. Easy to apply with a rag or foam brush (I used the foam brush) and wipe off excess with a rag. A guy who was demonstrating it for me used a foam brush and wiped it down with paper towels. Thin -and clean up - with mineral spirits. Claims to cover 800 to 1,000 sq. ft. per gallon, and I believe it does. Beautiful satin finish, and about the easiest I've ever used. Maybe because the excess is wiped off, it doesn't seem to collect dust while drying. The manufacturer is S.J.Bailey & Sons, Inc., Clark Summit, PA 18411
I managed to get sidetracked on the cabinet job today, and know I won't get to it for the next couple days. But I'm looking forward to doing it.
Fred - thanks for all the info. It makes sense that the gel makes less mess and sounds like it's pretty easy to work with.Paul
F'burg, VA
Paul- thank YOU. This was my intro to participating in the forums, and already I'm hooked. Great place to learn.
Fred, you're right, the gel varnishes are very easy to work with. Keep in mind, each coat of a wipe-on wipe-off finish is significantly thinner than a coat of finish applied by brush (one reason for the quick-drying aspect and minimization of the dust that gets into the finish).
In one sense, that leads to a lot of waste, and you'll need to be prepared to deal properly with all of the rags. You'll also need to apply two to three coats of gel finish for every coat that you might have otherwise applied by brush, in order to get an equivalent degree of build and protection.
David"The world that was not made is not won by what is done" -- Mundaka Upanishad
David - I agree with what you've said and think I should be putting on another coat or two. I've been wiping the excess with paper towels. Works fine. This house has a hot air furnace so dust is a problem. The poly gel seems to help eliminate a lot of that particular curse.
Fred
