What is the best way to refurbish the table top of a old cabinet table saw? Mine has some pretty deep scores in it .
Here's a method that works surprisingly well with surface rust.
Take one of your sanders -- a ROS is best -- cut a piece of Scotch Brite pad (green), and set it on the pad of your sander. If your sander uses H&L sand paper, the sander pad will hold the SB in place. If you have a pad sander (without the H&L), attch some coarse sand paper, and that will keep the SB in place once you put some pressure on the sander.
Mist the TS top with a lube (I use plain paint thinner),and sand away............
Wipe off the sludge with a cloth damped with pain thinner, and when dry, apply a coat of furniture paste wax (not auto wax).
EDIT: I just saw your comment about deep scores. That problem is outa my league, and maybe someone else will come by with a suggestion.
John Wooden 1910-
Edited 2/10/2007 1:43 pm by nikkiwood
I'd have thought that after the abrasive cleanup that flatness of the table would have been the next consideration UNLESS the scores are so wicked-gouges-that they affect overall flatness. If this is the case, go directly to a machine shop (but do the cleanup unless you want to pay them to do it). Hope this isn't so. Clean it up, then check the flatness with a GOOD strightedge and feeler guages, then sort it out...Good luck!
