I am just a beggener in wood working. I took classes in high school and want to contune with wood working. I am in the prosses of finishing my garge and wanting to know what hand tools to get. My wood teacher had us start with hand tools and I would like to relearn with hand tools. I know about the 5,000 start up but to get the basic with hand tools first.
Thank You
Todd Smith
Hello,
Thanks for your question.
I found an article about setting up a shop:
http://www.taunton.com/finewoodworking/FWNPDF/011100058.pdf
There is a lot of info in this story that may be helpful to you, but here is a section that specifically deals with hand tools:
While you may not think of it as a hand
tool, the workbench is where most of your
handwork takes place. It may well be your
single most important tool. A good workbench
should have a flat top, be sturdy
enough to take a pounding and not wobble.
The bench should also have both tail
vise and shoulder vise or the equivalent. If
you can't afford to buy a good European
workbench (about $1,200), building your
own bench should be one of the first projects
for your new shop. You can find the
bench hardware for about $115.
I've found the following hand tools to be
indispensable. I've explained briefly what
each is used for as well as what you should
expect to pay for a good tool, assuming
you shop smart.
Folding rule and a tape measure. My
favorite measuring device is a 6-ft. Lufkin
Red End carpenter's rule with extension
slide. It's durable, handy and accurate. $18
(for the folding rule) and $ 14 (for the tape).
Square. I use several squares regularly:
a 4-in. engineer's square, a 6-in. try square
and a 10-in. try square. If I had to settle for
only one square, it would probably be either
a 10-in. or 12-in. try square. $25 (for a
10-in. try square).
Sliding T-bevel. Indispensable for marking
out dovetails and angles. $14.
Mat knife. For many purposes including
marking out joinery. $4.
Chisels. I recommend buying a set of
durable, plastic-handled bench chisels,
such as Marples Blue Chip, in sizes in.,
in., in., in., in. and 1 in. $45.
Shop
environment
A good shop environment is as
important as which tools you buy.
Adequate lighting is essential, and a
window can help keep a small
shop from feeling like a prison cell.
One of my first workshops was a
dark, 150-sq.-ft. concrete basement
where I had to stoop to duck pipes
and beams—it was depressing. My
next shop was a one-car garage
(200 sq. ft.), then a two-car garage
(400 sq. ft.), then a storefront in
New York's Little Italy (250 sq. ft.)
and, at last, a l,200-sq.-ft. loft in an
old factory. Based on experience,
I'd say the smallest comfortable
size for a woodshop is 400 sq. ft.,
although I would choose to make
furniture in a smaller space rather
than not at all. —P.K.
Handplanes. The first two I'd get are a
block plane and a jack plane. The block
plane is for planing joints flush, planing
across end grain, fairing convex curves,
and breaking edges. The jack plane is for
flattening wide roughsawn lumber and for
smoothing machined surfaces. $45 (block
plane) and $73 (jack plane).
Marking and mortising gauges (or a
combination gauge). For marking mortises,
tenons, dovetail shoulders and for
marking stock to be resawn. $34 (for a
combination gauge).
Hand scraper. For smoothing surfaces.
Sandvik makes the best. $7.
Hacksaw. For cutting joinery. I use a
small, inexpensive saw with a 10 in. by
in. blade. Its 21 tiny teeth per inch leave
a very thin kerf. $13.
Coping saw. For removing waste when
cutting dovetails and for sawing interior
curves. $14.
Awl. For marking pilot holes. $7.
Wooden mallet. For driving chisels. $14.
Hammer. For a multitude of uses. $ 16.
Twist drill bits. From in. to in., by
64ths. $48.
Brad-point bits. From in. to in. by
l6ths, plus in. and in. $40.
Half-round rasp and wood file. For
smoothing curves and shaping edges.
$16 and $14.
Mill bastard file, 8 in. For scraper
preparation and for odd bits of metal
filing. $6.
Water stones, 1,000-grit and 6,000-grit.
For sharpening chisels and plane blades.
$47 for the pair.
Clamps. I recommend buying six -in.
C-clamps, six 12-in. quick-action clamps,
six 24-in. quick-action clamps, and six 4-ft.
bar clamps. About $275.
Although $6,500 or so (a rough total) may
seem like a lot of money now, it is almost
a negligible sum when amortized over a
lifetime of pleasure, productivity and value.
Buying good tools to start with and
making sure that they're the right tools for
the job, will get you off to a good beginning
on your career as a craftsman.
Sincerely,
Gerald La Starza
Fine Woodworking
The reason that I ask this question is that I don't have much money to start with. So if I get things like planes and saws I would still able to work on boxes to get started. I do have a 3 hp Tablesaw, and soon a compund miter. I was also wanting to know I could do a lot of things by hand if didn't get all the power tools? and maybe names of specilty tools. What kind of water stones do you recmend to get?
Edited 1/1/2009 2:04 am ET by GaySafariShorts
Hi,
What kind of projects do you plan to build? This will give us a better idea of what kind of cost-effective tools to recommend.
I was going to start out with hand tools first untill I have the money for more power tools. So things like small boxes to get the jointing down. I have a list of tools but it does not seam like it is all of the tools for starting out by hand or with hand tools. I have a few plans for small boxes, and I Just want to make sure that I don't waste money.
Hi,
If you are starting out, a good idea is to get used tools at places like flea markets or ebay. Here is a link to an article on that subject: http://www.taunton.com/finewoodworking/ToolGuide/ToolGuidePDF.aspx?id=24969
Chisels are essential for box making. Here is a link to an article on chisels: http://www.taunton.com/finewoodworking/ToolGuide/ToolGuidePDF.aspx?id=31061
This chisel is cheap and it tested well:
Narex: Best Value Western-Style.
Here is a link to a video on sharpening flea market chisels:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=28817
Here is a link to an article on waterstones:
http://www.taunton.com/finewoodworking/ToolGuide/ToolGuidePDF.aspx?id=2901
An inexpensive way to sharpen is with sandpaper and glass:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=25403
If you want to get a waterstone, the Norton Combination Waterstone is good:
http://www.woodcraft.com/product.aspx?ProductID=818264&FamilyID=4486
I would also investigate some planes and dovetail saws for making boxes. I would start with cheaper tools and then take the plunge into the higher grade equipment when you want to get more serious.
Best of luck,
Gerald
Thank You for all the Info.Todd
