Hi
What kind ,or where do you get a good remote control switch for the dust collector?? I have one i bought from woodcraft. ,wired it up ,did not work , called teck. assistance. they told me to replace battery and check switches inside that they were all in same position in the transmitter and reciver . all ok I sent that unit back they sent me a another one . Same thing. Needles to say I am kind of fustrated .
Have a nice day Lee
I don't know exactly what your unit does....I think your switches are still the problem......are these DIP switches? like thekind ina garage door opener? and are you looking at both the same way, use a toothpick or tiny screwdriver to make sure they are set
...just my thoughts....sometimes they look flipped,
Hey, I might have the same unit. Is your switch the size of a key fob for your car on a little chain? if so, I have the same unit. Mine is for 250V. If you checked the dip switches and they are the same, then, I would suspect the receiving unit. Call and have a whole new unit shipped. You might also check to see if the receiving units breaker got tripped. Mine has a little one like you see on some power strips. Good luck.
The dip swiches are the same. mine has a reset button on top tried resetting that. still nothing.Mine is also 220. Kind of strange i would get 2 bad units.
Have a nice day Lee
I will send this unit back also. Thanks for your input
I bought my remote switch with 2 remotes for $34 from Grizzley 3 years ago. No problem same batteries and it still works perfect.
