Does anyone have any great methods for removing glue, Titebond II, from clothing? My shop apron is caked with glue and seems to stand on it’s own from glue that I’ve wiped off my fingers. I have some jeans with glue on them that I’m not quite ready to dedicate as shop pants just yet also.
Jeffrey
Hi Jeff
Most of my work involves hardwood flooring. I did use Titebond II and had the same problem you are having. Then I got to thanken (oh no) if there is enough moisture present to cause the glue to fail my floors have even a bigger problem. So I went back to Titebond. Now I throw my apron in the washer, problem solved.
Jeff in so cal
75 f---47%
I think the question, the problem, is interesting and practical.
I was brought up in the Great Depression and taught to "use it up, wear it out, make it do, or, do without."
So I tried to work clean around the shop. For several years I wouldn't wipe my hands with glue on the fingers on my shop apron. Too dirty, thought I.
But I apprenticed to a German woodworker and he said, " That's what the apron's for/"
So for years I've wiped whatever glue I'm using off on my shop apron.
Now, then, I'm posting this to ask you guys: What happens to Titebond and Titebond II and White Glue and other common glues, when I toss my apron into my dear wife's laundry?
Is the glue still there once it's been through the washer and drier?
Should we add something to the wash water to help the glue disappear down the water drain?
I haven't really thought about it.
Anyone out there REALLY KNOW?
William
I make something, sometimes twice, each year.
Seems to me that you are in the best position to find out. Take off your apron and throw it in the wash. Get back to us to let us know what happens.
I regularly re-constitute hardened glue brushes by soaking them for 10 minutes in hot tap water. Glue softens and comes right out by working the bristles in the bottom of the container.
You may be able to remove it by using boiling or almost boiling water. The Titebond II is not impervious to over 160 to 180 degrees. The fresher it is, the better the chance of it working.
