Hi all,
Just received an antique cradle that was poorly repaired (and naturally re-broke) leaving heavy dried glue. The panel break is 3/8 x22″ long and I really don’t have time to refinish the entire cradle. Is there any other way to remove glue other than shaving and sanding? It would be an easy clean break except for 2 coats of glue.First coat didn’t touch ( obviously unclamped) dried nice and shiny, second coat I got most of with a razor.
Beedy eyes,
Try to use warm vinegar and lay the panel down level,
to contain the liquid from dripping off.
Wipe off the softened glue occasionaly (Toothbrush)
and repeat ( alternating on both sides)
It may help to gently wedge the split apart,
to allow the 'Juice' to work it's way inside the break .
When most of the glue is gone and the panel
is no longer wet, use Titebond ll glue, clamp and wipe off any excess glue with a slightly moist cloth. Steinmetz
thanks
Bd,
I'll echo what steinmetz said, with these additions: Try hot water first, if it will soften the glue you will be better off. Try to get all the old glue off, not most of it. Any remaining glue will prevent a perfect realignment of the split, and a good glue bond. If you must use vinegar, wash with water and baking soda solution to neutralize the acid. Titebond will work, but hot hide glue is preferred for repairs to antiques, as it is compatible with the original glue that was likely used, and more easily reversed if a future repair becomes necessary.
Heat alone softened the glue to facilitate removal, unfortunately, I know why they used so much glue. A 14" piece in the center appears to have splintered out leaving a 1/16 to 1/8" gap in the center. BUMMER. Black walnut is hard to come by. Possible disassembly and repair at a later time.
Thanks for the input
Bruce
