I am trying to refinish a walnut table top (veneer) that is badly stained (black) by a leaking flower pot. The stain persists even after stripping and sanding. Can anyone tell me how I can remove the black stains? Bleaching? With what? I would appreciate the help.
Doc:
Thanks for the vote of confidence,however working on old furniture is not my strong point. The first idea that comes to mind is to try a chlorine based
bleach.
I am certain that someone more qualified will pick up on this and will be able to help with your problem.
¬¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬¬¬
same question just below under bleaching walnut in finishing. Oxalic acid is what you're after.
Black stains occur when the moisture actually gets into the wood fibers :-( as opposed to white stains, which are in the finish only. Bummer. Hope the OA works for you.
Thanks to both of you. I"ll give it a try. Doc
